Moving BkGnd slows to a stop b4 Cycling?
HollysBaby
Post by HollysBaby »
I’m trying to setup a moving background (a walk in the woods).
I start @ frame 1 and move the background into another position @ a new frame (30) and set that frame to “cycle” back to frame 1.
When played the background moves but slows to a stop as it approaches frame 30 before it cycles back to frame 1, causing the background to start-move at normal speed-slow-stop-cycle.
PLZ HELP A ROOKIE
Thanks
Right-click the keyframes of the BG and set them to "linear".
You may still see a small stop of the movement. When I set up a loop, I copy a pose from frame #1 to frame #31, but set the cycle length to 30. If I'd set it to 31, the pose would be repeated for 2 frames, thus causing a small but visible stop.
