Cycle stop keyframe identical to first
I have created a simple cube, and am rotating it continuously, on a cycle setting at the last keyframe.
I would like to know how you can easily make sure that the cube's ending position at the last cycle keyframe is identical to the first keyframe, so it cycles smoothly. I tried the Reset feature like in the tutorial, but that would "rewind" the cube before starting it over again. Any help appreciated.
Andrew
Andrew
Maybe I'm not understanding the full picture,
but there's 2 things that come to mind.
- You want to cycle for example from the last frame back to the 2nd frame,
where the first and last frame are the same. (Or delete the last frame and
cycle back to frame 1, whatever.
- Check the forum for cycle issues in AS6. (And AS5.6, apparently
there are different issues in each, and a patch for AS6 in the pipeline.)
I'm using 5.6 The cycle works fine, I'm just wondering if there is any tip or advice on how to quickly, when creating the cycle, make sure that the positioning of the animated components, whether it be translation, bones, etc, at the end of the cycle is the same as at the first. If you're off by just a little bit, the cycle has a jerk at the end.
- Víctor Paredes
Yep. Copy and paste the first keyframe to the last keyframe, and cycle.
Or, if you rotate a cube, if the first keyframe is 0 degrees rotation, after 20 frames or so enter 360 or 720 degrees rotation in the dialog box and cycle that. That will make sure the cube does a full rotation and you won't get any jerkiness in the cycle
I sure am saying this.
If you read the tutorials...oh, never mind.
Its at the top of the screen on the left in the main screen. rotate the object and you'll see the numbers change once you've rotated it. Also, you can mousewheel while the cursor's in the dialogue box to change values and see the results quickly.
- Víctor Paredes
