Is it possible to change the Shotcut for Peak and smooth?
In previous version of AS Shortcut for Peak - 'P' and for Smooth - 'M'. But in AS PRO 6 Ctrl+P and Ctrl+M. Possible to change the shortcut as previous version? Because holding Ctrl key is difficult to me for the process of Smooth and Peak.
I love Moho
- Barry Baker
Look at this discussion:
viewtopic.php?t=13515&highlight=smooth
I had the very same issue with v6. You will need the peak and smooth tools, as well as their icons, from v5.6 to be able to change it back (lm_smooth.lua and lm_peak.lua). Put them in the scripts\tool folder, then edit each lua file to take out the word LOCALIZE, which is incompatible with v6.
For example,
For example,
Then you need to change _tool_list.txt in the same folder by adding the following lines:It should work without any changes -- if there are problems they are most likely with any LOCALIZE statement. If so, you can safely remove the LOCALIZE function: that is, if it says something like:
LOCALIZE("Hello young lovers") change to "Hello Young Lovers".
Put these lines where you want the buttons to appear - I have them directly after lm_curvaturebutton lm_smooth M
button lm_peak P
I have put the peak and smooth buttons and changed the _tool_list.txt. Works as well. But lua console error shows.
I didn't understand in this script. How can remove the LOCALIZE function?
I don't have script knowledge.function LM_Peak:UILabel()
return(MOHO.Localize(self.BASE_STR + 1, "Peak"))
end
I love Moho
- Barry Baker
