Fading out
kettricken
Fading out
Post by kettricken »
Hello again,
I'm trying to animate some basic ripples spreading out and fading away, but I can't work out hoe to get them to fade. They're just simple unfilled vector circles on a greenscreen background, nothing fancy - can anyone tell me hoe to get them to fade from 100% to invisible over the space of 30 frames?
Thanks a lot
kettricken :D
I assume you are uing 5.6 Pro? You don't say...Anyway, transparency is an animatable feature. Make a key frame where you want the transparency effect to start, advance 30 frames, and set transparency to 100 or whatever. Sit back and watch...
kettricken
Re: Fading out
I'm actually using Debut (the latest one). I've tried adjusting the layer opacity, but that doesn't seem to work; I'm not sure how to alter the transparency. Any hints?
Layer opacity does work, but you must render the file before you can see any effect.
kettricken
Ohh, thanks :D
kettricken
Finally got it - had to turn on the 'allow animated layer effects'. Thanks for all the help :)
