Picking up objects.
da2tha3
Picking up objects.
Post by da2tha3 »
Okay, I was wondering how to make a character easily pick up an object that is initially stationary on the ground. So far the only way I've been able to do it is to put the object into the same bone layer as the character, and bind it to a separate, stationary bone, until the character moves to pick it up. I then need to manually, frame-by-frame, match the movement of the object to the character's hands.
I'm thinking there must be a fix for this? In 3D apps, this is acheived by parent constraints, but Anime doesn't deal in those. Any help?
The easiest way is to have 3 layers: object, hand with object, hand without object. The two hand layers are inside a switch layer. As the hand (without object) is about to pick it up, switch the layer to 'hand with object', and make the object invisible. Voila! You have picked up an object...
da2tha3
Post by da2tha3 »
Thanks for the reply. In most cases this is sufficient, and just requires matching up the points of the object on both layers, then having the switch over. However, how do you set a bone to affect the vectors held within a switch?
Not sure I follow. Can you give an example?
da2tha3
Post by da2tha3 »
Okay I've created a quick example hand file, which looks better than expected.
http://da2tha3.hostrator.com/HandExample.zip
However, if you open the file and look at it, you'll see that what I'm referring to is that the hand switch layer can only be parented to a single bone, which in this case doesn't present a problem... I was just wondering if there is indeed a way to have a switch layer influenced by more than one bone, or if I would need to create everything, as I have in the example, as seperate modules?
You can insert bones in switch layers, and you can nest switch layers -- I thnk this can cover most eventualities.
arfa
Post by arfa »
You don't really need a switch layer.
Hand -- with (invisible) paper bound to it. This way points can be tied to any bones you want.
+ visible paper
Hand moves - static/visible becomes invisible
Hand paper now visible.
The main thing is getting the two to line up at the vis/invis point.
You can have any number of objects bound - some visible, some not - although it can get a bit confusing as you work.
- arfa
da2tha3
Post by da2tha3 »
This is the problem I'm having. It all adds to confusion. If only bone parenting could be edited as I described, it'd be the perfect and user-friendly solution.
arfa
Post by arfa »
da2tha3
Have you tried fa_reparent_bone.lua? - one of Fazek's tools.
arfa
da2tha3
Post by da2tha3 »
I have, but that only allows editing of parents on frame 0. I'm talking about changing the parenting along the timeline, animating it. I'm assuming it's not possible and the layer thing is the only workaround, but I thought I'd ask.
arfa
Post by arfa »
No, bone parenting is not animatable.
rogermate
Post by rogermate »
da2tha3 wrote:I have, but that only allows editing of parents on frame 0. I'm talking about changing the parenting along the timeline, animating it. I'm assuming it's not possible and the layer thing is the only workaround, but I thought I'd ask.
Here's an idea which might be helpful in some situations.
You could break the scene, as far as your workflow, at the moment the hand picks up the object. You wouldn't need to do a cut scene, the viewer wouldn't have to notice there was a break. But you could have a new .anme file for the "new" scene at the point where you want the parenting to change. Then just animate from there.
Obviously, this is a big work flow change. But it might be helpful for certain projects where there is a lot of animation under one bone parenting layout and then extensive animation thereafter.
