animating layer opacity?
bisagaboo
Post by bisagaboo »
Not sure why this doesnt work in ASP 6 because it was easy in previous versions.
If you wanted to animate layer opacity, all you used to have to do is move to a particular frame, then change the opacity value in the layer options and it would create a keyframe on the time line.
This no longer happens in ASP6. Changing the opacity value only changes the value for the entire duration.
Am i missing something or is this a bug?
dueyftw
Post by dueyftw »
Your missing the new check box just above 'animate layer opacity'
Why would anyone need to have a box to turn on this feature, I have no clue. There should have been 'Clear animated layer opacity' Now that would be useful.
Dale
