Sound poping in audio & color bleeding
Dj Manik
Post by Dj Manik »
I figured I would kill 2 birds with one stone.
The animation is coming along great, but when I render, the colors are bleeding out of my characters, I can't figure out why ?
Also, I am using wav files for my audio and everything should work fine but the sound is popping and cracking and causing ASP to Glich. I am usuing ASP PRo 5, haven't upgraded yet ..
Can Anyone help me ???
For the bleeding effect, it would help a lot to have a image of the effect.
Regarding to audio it might depend on which codec are you using to export the movie.
xothermik
Post by xothermik »
with regards to the color bleeding. you probably have an opening on one of your shapes, check your vector points carefully and ensure they are welded and closed. if it still bleeds try selecting and deleting the color bleeding and apply ur style again. had that problem once i think that was how i solved it.
Dj Manik
Post by Dj Manik »
Thanks for the Fix on the color guys !!
as for the sound, its popping and causing ASP to glich while I am animating .... any suggestion ??
xothermik
Post by xothermik »
hmm interesting. and the original audio does'nt do this? ur can try convertin the audio to wav if its is'nt already. im not sure but i feel it works better with p.c apps. good luck.
