Brushes overrun corners
arfa
Post by arfa »
I have been experimenting with a few custom brushes and wonder if there is some way of having the brush turn nicely at peaked corners. This example has a relatively long stroke but the same issue seems to apply generally.
I have tried altering brush length/shape/width, changing line width and a bunch of other things. Adding extra points is a workable solution but falls apart with animation.
If there was a clever trick one of you clever people knew I would like to know.
You work best with round brushes - AS stamps each brush with its center on the construction line, beginning at the corner points.
