Ant walking
patricia3d
Ant walking
Post by patricia3d »
Work in Progress.
Ant created in Anime Studio Pro 6.1
Hope every one will like it.
Very nice!
Now let's move it ... Are you going to use these as particles?
patricia3d
Thanks Slowtiger for your comments. 1st I will rig it and try to make it walk. If I don't get success, then I will try to use as particles.
kkrawal wrote:Thanks Slowtiger for your comments. 1st I will rig it and try to make it walk. If I don't get success, then I will try to use as particles.
You can animate a walkcycle and put that rig inside a particle later. Bones and particles aren't exclusive.
patricia3d
Thanks Selgin for your comments. Its a good idea. It will be like the Hen Particles given with 6.1.
patricia3d
I have modified some part of the ant
and walk 120 is here
http://patricia3d.webs.com/ant41.swf
Please give your idea.
Make a six leg walking cycle is quite complicated. Also make it turn is even more complicated.
The design is fine (I would change the eyes into other type) but I think that they should walk faster. Also some antenna movement and some stop/runs would work too.
Good luck with the challenge :)
patricia3d
Thanks for guidance. I will do these changes and show again.
