Why Switch Turn is so smooth?
patricia3d
Post by patricia3d »
I have got switch_turn.anme file from the forum, I have forgot the forum link. While studying this file, I created one Square and
one Round with 4 Points 2 Vector Layers and put them in a Switch.
http://cid-ce583d1094a511ea.skydrive.li ... chturn.zip
Please unzip and you will get switch_turn.anme
Original File has switch layer Turn Control
and I have created switch layer myTurn
I don't know why original Switch layer turns head smoooooooooothly and why mine is
not turning smoothly?
LeeHasPencil
Post by LeeHasPencil »
Have you selected 'Interpolate Sub-Layers' in the Switch properties?
If not,
Double click the switch layer to open its properties.
Select the switch Tab
Tick the box 'Interpolate Sub-Layers'.
Should turn smoothly now.
Hope that helps.
patricia3d
Thanks for answer so fast.
In the uploaded file
'Interpolate Sub-Layers'. is not checked.
But I checked this in the file I hve just now but even that my switch layer its not turning somoothly?
LeeHasPencil
I'm still a newbie myself, so can't offer much help, sorry.
Interpolation on switch layers only works when each layer has the same amount of points.
kkrawal wrote:Thanks for answer so fast.
Switch layers seems to not interpolate curvature.
viewtopic.php?t=6043&highlight=curvatur ... nterpolate
patricia3d
I tried different ways, but its not doing. While study this, I found one more secret in this file that Just change the Name of Head Layer and the smooth turn will finish?
kkrawal wrote:I tried different ways, but its not doing. While study this, I found one more secret in this file that Just change the Name of Head Layer and the smooth turn will finish?
No, simply you have broken the current inserted keyframes. They are based on layer names. If you change the layer name the keyframes that references the old layer name are not changed.
patricia3d
Thanks Genete.
One more secret of Anime Studio Pro I come to know . Can you please guide howto make my Square and Round ( both 4 Points ) will transform smoothly..
The only way is use the curvature tool. Also I would use 1 frame actions for that task.
