layer visibility
katz
layer visibility
Post by katz »
as i read in many posts there is supposed to be a layer visibility channel in the timeline... to make a layer invisible and visible again on different keyframes. its probably very simple, but i just can´t find this channel!!
where is it? i´m using anime studio pro 6. thanks for any help.
It's in the layer properties (doubleclick layer). It is always set to visible as the default, which means that you have to set it to invisible to create the timeline and a key. Go to another frame and set it to visible again if necessary.
The same goes for creating layer transparency: the default is 100% (opaque), 0% means invisible.
katz
Post by katz »
thanks, i just found out... i can turn off visibility and the invisible part is marked red in the timeline... but i can still see the layer. do you know what i´m doing wrong?
muffysb
Post by muffysb »
Hi Katz,
Invisible layers are still visible if you select them in the layer list (because AS assumes you want to edit the selected layer)...try selecting a different layer and see what happens.
Cheers,
Muffy.
katz
Post by katz »
hi muffy, great... sometimes its so simple, and still takes me ages to find out...!
thanks a lot!!
