green screening in anime studio
swrecordings
Post by swrecordings »
i know you can do it with masking but to do it for a long video takes ages. is there a quicker was to do it in anime studio then the masking?
thanks in advance
sw
J. Baker
Post by J. Baker »
swrecordings
i found i have a software that does it, i was just wondering of there is an easy way to do it in AS. ah well.
Rhoel
Post by Rhoel »
SW,
I don't quite follow what you are trying to do - are you trying to incorporate a green screen shot or just output to another composite program?
If its just outputting with a green screen, why not just use the alpha.
If its a removal of green screen, more difficult, as most screens are not "flat colour". There is a way of using the Layer Blending mode option but I have to check the combination.
Rhoel
swrecordings
i am trying to remove the green screen from a video. i found i have a piece of software that does that. but i was hoping to be able to to it all in AS. guess not.
swrecordings
actually, my software is not exporting the alpha after the green is removed. lets see what i can get from this software...
swrecordings
the new software is telling me that i need to have "avisynth" installed. where can i get this?
Rhoel
Post by Rhoel »
SW, I tried several combination of the Layer Blend but to no avail - I can kill the green screen but the background is a new colour, not transparent.
The only program I have which can do this is Combustion, which isn't cheap.
The alternative is to do the composite in an edit suite - many have some green screen support.
Rhoel
Many stop motion frame grabber programs have green screen removal features built in. Try Helium Frog -- it's free!
AS can't remove the green or any other colour because it uses images and videos as a closed container, not looking inside the pixel values. The only thing it recognizes is an alpha channel. So you need to create that alpha channel in other software prior to import video into AS.
A recommended codec to use for importing video with alpha is "PNG, millions+ colours".
