image texture on a cube
- swrecordings
is there a way to make a cube (imported scripts--> 3d--->cube) with an image texture on it?
Yes, the texture has to be baked onto the cube first, eg, with Blender: A materials file with the object then links the baked material jpeg to the cube. The whole thing is loaded into ASP at the same time as the .obj.
If it doesn't work. open the material file in a text editor and check the paths. For ASP, everything has to be in the same directory.
Rhoel
Rhoel
