I can't seem to save my project settings defaults to Youtube or Youtube HD, I save as default but it always reloads as HDV/HDTV 720p. Anyone else having this problem or is this the way its made to work? I also notice that it does this on a few other settings.
I did not post this as a bugs because I am not sure if this is the ways its designed to work.
Youtube HD defaults setting
Ah, so OK I do not need to reset it from HDTV back to Youtube HD each time I render a movie? I am kind of confused why there is HDTV and Youtube HD as options when they one in the same. LOL I'm so confused.PARKER wrote:HDV/HDTV 720p and youtube HD has the same dimensions.
When you want to watch your videos on youtube in HD, export with HDV/HDTV 720p, it will work perfectly.
I do a lot of AS stuff on Youtube in HD, so I should leave the HDTV as is and not reset it to Youtube HD each time because its the same?
Check the width and height of both dimensions, they dont change because they are the same.sbtamu wrote:Ah, so OK I do not need to reset it from HDTV back to Youtube HD each time I render a movie? I am kind of confused why there is HDTV and Youtube HD as options when they one in the same. LOL I'm so confused.PARKER wrote:HDV/HDTV 720p and youtube HD has the same dimensions.
Yes, leave it in HDV/HDTV 720p.
M'kay iIll just leave it at HDV/HDTV for now onPARKER wrote:Check the width and height of both dimensions, they dont change because they are the same.sbtamu wrote:Ah, so OK I do not need to reset it from HDTV back to Youtube HD each time I render a movie? I am kind of confused why there is HDTV and Youtube HD as options when they one in the same. LOL I'm so confused.PARKER wrote:HDV/HDTV 720p and youtube HD has the same dimensions.
