broken .anme file
PARKER
broken .anme file
Post by PARKER »
I have a broken .anme file, when i try to open it a small window opens an says: Bad file header.
Can somebody tell me how to fix it??
Re: broken .anme file
PARKER wrote:I have a broken .anme file, when i try to open it a small window opens an says: Bad file header.
If I were you I would create a new file and open both in a text editor and make a comparison of the header. Depending on how many is corrupted it can be recovered or not.
neeters_guy
Post by neeters_guy »
What does it say after "Bad file header"? Sometimes it will show the offending text. Did you create this file or download it?
PARKER
Post by PARKER »
neeters_guy wrote:What does it say after "Bad file header"? Sometimes it will show the offending text. Did you create this file or download it?
i created it.
neeters_guy
Hmm. I've seen this error when I tried to use MSWord to edit anme files. Despite being saved to "plain text", the encoding damaged the file for some reason (ie., Bad file header). So I only use notepad or SciTe if I need to peek or edit the file.
I assume this isn't the case here, so Genete's suggestion seems to be the best option.
Sorry, that's all I got. :cry:
PARKER
Post by PARKER »
I open the broken file with Note pad and Word but its totally blank.
