...create a circle with more than 4 points?
mkbth
Post by mkbth »
Is there a way to create a basic circle shape with more than 4 points, or do you have to add the points by hand after making it?
Very new to Anime Studio. Thanks.
jonbo
Post by jonbo »
try ;script;draw; polygon.set # of points to 8. then with the points selected goto;draw;smooth. i tried 8, 10, and twelve points on the poly and its not perfect but might work for u. :)
mkbth
Post by mkbth »
Thanks. Still have to do a bit of tweaking with the curve tool but that works well enough.
sbtamu
Post by sbtamu »
One other way is to draw the circle with 4 points then use the draw/split curve script.
Sorry for bad animation
