Hi all,
it seems to me that the space bar and ENTER keys (for run animation and deselect points) are precisely backwards.
I need to deselect points dozens if not hundreds of times per hour, and launch an animation at a much lower frequency.
I'd like to swap these functions (there is nothing more annoying than having to let go of my mouse in order to deselect points... then to find my mouse again)
Is there a way to reassign these hotkeys?
thank you!
Ryder
Changing keyboard shortcuts for NON script controls
- funksmaname
- funksmaname
sticky on the scripting forum:
viewtopic.php?t=12334
HOLY SMOKES, these tools are amazing!funksmaname wrote:sticky on the scripting forum:
And the sad thing is... they are just basic tools!
Has anyone done any work with respect to eliminating some of the existing AS tools...
If there are experienced AS'ers out there that know which of the original tools are safe to remove... I'd love to hear how the Fazek Tools (tm) are properly implemented (mine are located in the "OTHER" tool space).
Ryder
- funksmaname
'Other' is fine, there's no point removing the main ones, but you might want to reassign your shortcuts... if you open you script/tools/_tool_list.txt file, and add this at the bottom:
and change the lm_ ones with those shortcuts to ... (you'll see what i mean when you look into that file) then fazeks tools will get selected instead of the normal ones when you hit the shortcuts.
tool fa_add_point A
tool fa_translate_points T
tool fa_create_shape U
tool fa_curvature C
