Bone Copy?
Bone Copy?
I have run into a snag. I created all my "body parts" on different layers (which is fine), but... I also created a seperate bone layer for each body part. Then I placed all of body parts in their respective bone layers, thus I was able to animate each piece seperatly. I then put all of the bone layers in a "parent" bone layer for the entire body. This method works fairly well for the main animation window, I click which part I wish to animate, I manipulate the bones of that layer, I click the next part, etc etc. However, I found that if I wish to create a reusable "action" I have to create an action for EACH layer, which gets confusing and messy. So, I am left with 3 options, 1. Work with the mess, 2. Dont use actions, 3. Copy the bones all to one layer (lots of bones, with lost of constraints, and specific placement, I REALY dont want to have to redo them all), but I dont know if its possible to copy bones from one layer to another??
- Lost Marble
Re: Bone Copy?
Expanding a little on the previous answers:DaBeav wrote:However, I found that if I wish to create a reusable "action" I have to create an action for EACH layer, which gets confusing and messy.
DaBeav, (after a very simple and quick test) the trick (as suggested by Ramón and Lost Marble) seems to be to select the parent bone layer in the Layers hierarchy panel before selecting and inserting the action, which then applies the all the action sub-layer keyframes as well.
If you have a bone sub-layer selected in the Layers panel when you insert the action, only the sub-set of the action for that layer gets inserted, which seems to be what you're seeing.
Hmm, that could actually be useful for your kind of multi-bone-layer setup - have, for example, a walk action with swinging arms. Now if you want the character to walk while carrying something, just select the leg bones layer and insert the walking action but not the swinging arms.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
