Is there an obvious way Im just not seeing?
If there isn't a solution then I think there could be a feature request to do some sort of reverse of 'Track layer to video'.
Use motion tracking to fix handshake?
- Víctor Paredes
Ok, you have to invert the tracked movement by hand. I mean, using a logical layer order. It's not easy to explain, but basically you put the video inside a couple group layers and flip them to invert the tracked movement.
So here is it a kind of tutorial step by step:
- track your video
- create a group layer (Group 1) and apply track layer to video
- put your video inside Group 1
- Create a new group layer (Group 2) and flip it on X and Y axis
- Put Group 1 inside Group 2
- Flip the video layer on X and Y axis
That's all, I think. So your layer window should look like this
_Group 2
___Group 1
_____video layer
I hope this helps.
- track your video
_Group 2
___Group 1
_____video layer
I hope this helps.
- Víctor Paredes
Hum, that sounds logical... I'll try at home. Thank you, slowtiger.slowtiger wrote:Hm, wouldn't it be easier if you rotate the video 180° before you track, then return it to 0° in the end?
