.svg
montyman77
.svg
Post by montyman77 »
I have a lot of .svg files that i want to import into anime studio
i made them in inkscape so does anyone know how to export it from there in a proper format?
or is there a freeware that can convert them in windows?
thanks I'm new to AS
montyman77
I also have GIMP if that helps and my version is AnimeStudio PRo7
Someone else had successfully imported Inkscape files to AS, search for it in the forum.
AS only reads EPS and AI files.
montyman77
I can only find requests for this feature, not an actual sollution
Uolter
Post by Uolter »
There's no way to import svg. The only thing you can do is to convert svg files to illustrator 8 then import in AS.
montyman77
Uniconverter is perfect but it only works on linux and I use windows
sbtamu
Post by sbtamu »
You state that you have GIMP, I think with a script you can convert your svg files.
A shot in the dark, I have actually never used, this site might work.
http://image.online-convert.com/convert-to-png
Sorry for bad animation
