How do you export both audio files
3deeguy
Post by 3deeguy »
I just found when I tried to export audio for two characters I got no sound. When I exported audio for one character at a time the sound came through. How do you fix this?
Cheers, Larry
sbtamu
Post by sbtamu »
Did you render the video at a frame other than 1? For example, If the audio file starts at frame 1 but you start the render at frame 12, it will not be in the final render even though you can hear it in AS. To make sure you get the audio to render, go to the sequencer in the time line and drag the audio file to the starting point. This is usually the cause of this but if this isn't the case then we will have to look at it closer.
Sorry for bad animation
3deeguy
Post by 3deeguy »
I just moved both 'wav' tracks to the top of the layer palette and exported frames 340 to 456 to Quicktime. I could see both audio tracks in the sequencer without scrolling. That time it worked. I'll have to wait until this evening to test the whole clip. My first character speaks at frame 340. The second character finishes speaking at frame 456. (If the problem is caused by file size I'm going to get 'depressed'!) :(
Cheers, Larry
