Soft edge
nobudget
Soft edge
Post by nobudget »
I have a small animation http://www.nobudgetvideo.com/moho/stephan_vliegtuig.wmv and if you look carefully the shiny parts on the wings alternate sharp/blurred. It should remain blurred, I put on a soft edge in the fill properties. The wings are scaled with bones. Any ideas? The only thing I can think of is that the points are too close for the soft edge to function properly.
Reindert.
Rai López
Post by Rai López »
I believe that as the wings moves the change of Soft Edge value (for scale compensation) is abrupt beetwen 1 to 2 directly (i.e.) or beetwen 3 to 2 (I don't know) I 've experimented this issue/BUG in others effects like Layer Shadow/Shading and seems that Moho doesn't work in this cases with decimals :shock: ...Am I wrong?
nobudget
Post by nobudget »
Possible, but the original value was 10, and 9 or 11 would not make that much difference right...where's the CIAO!...?
Reindert.
Rai López
Post by Rai López »
Hmmm... I know that you may want it ckecked (for several reasons), but has you tried to unchecked Scale Compensation for that layer? Only for be sure... And of course: :arrow: CIAO!!! (my friend) :roll:
nobudget
Post by nobudget »
Turning Scale Compensation off works!!! I did not think of that. Thank you my FRIEND! CIAO & BYE!!!
Reindert.
Rai López
Post by Rai López »
VERY WELL! :D I'm happy, yes... But that is not the best way to avoid this, because scale compensation affects all aspects of the layer and it's very likely that we can not want to unchecked it... cause of this we must insist in get more precission for effects procesing, a little more... ( :mrgreen: PLEEEASE :mrgreen: ) CIAO!!!
