Im runing on Windows XP pro SP2, PC is a 3.4 P4 with 1g of ram
and it gives no error it just shut down....BAMMM!!
and we have 2 PC on a network doing the same thing
by the way we are working on a 6 episode series of 30min each with a short deadline.
I never have shutdowns during editing, in fact Moho is very solid and reliable, only one strange phenomenon; in certain projects, usually more complex projects the program will not load it with the "open file" requester but if I double-click it from windows it loads fine. Maybe a memory problem (only 256MB) in XP but it's strange the loading WITHIN the program causes shutdown...
The only time that I've had that sort of shutdown is when I have been testing one of my own scripts and I've done something wierd. Is there a particular tool that you are using when it shuts down? Perhaps something has gotten corrupted. You might try re-installing Moho and see if that helps. Other than that, I dunno.
Is there any particular tool or menu command you remember using when the crash occurs? Is it with any kind of file, or one particular file? Any other information you might have would help.
The update is coming. Just trying to squeeze in a few more improvements.
