Drawing lines
bbuffington
Drawing lines
Post by bbuffington »
What is the best way to draw lines? For instance, in the image below, I had to add points to a sign to create legs/lines. Is there not a line tool?
https://docs.google.com/leaf?id=0B4Jig5 ... z&hl=en_US
GCharb
Post by GCharb »
You just use the add point tool with sharp corner checked, this will draw straight lines.
Then you add a stroke as you would any lines!
bbuffington
Yippee. Thanks!
Shepard
Post by Shepard »
For no open another thread, I write here.
When I draw with freehand tool, I have this "problem" (no brush):
http://img705.imageshack.us/img705/6734/catturakfs.png
How can I add the stroke in ALL the shape?
Thanks.
GCharb
Post by GCharb »
Go to freehand options and set variable line width to none, this way the stroke will be uniform, if that is what you meant!
