Keep character bone movement rate the same
bbuffington
Post by bbuffington »
Hey guys. It's my second day diving into Anime Studio Debut 8.
In my current project, I am having issues keeping character bone rate the same. In the following file, the two outside characters are suppose to in sync. However, even though the key frames were inserted at the same place and time, they are out of sync. Any help?
https://files.me.com/bbuffington/uwc9ac
jonbo
Post by jonbo »
the Robert character is missing a keframe on his left leg at frame 72. he has it on his right leg instead.
bbuffington
In that specific frame, I want Robert's right leg and Brian's left leg to rise at the same rate (Outside legs). But it still rises at different rate.
bbuffington
For instance, I just moved the center character "Whitney" up a little in Frame 72, but for some reason she gradually moves that way starting at frame 0. I only want movement to happen at specific frames.
jonbo
Post by jonbo »
i know what you mean. for the leg, select the right leg bone, and delete the key frame at frame 72. now goto frame 48 and with the bone rotate tool selected, click ONCE in the workspace without moving your mouse. this will place a key frame at frame 48 . now goto frame 72 and rotate the leg bone to where you want. now the motion will go from 48 to 72 . you can also copy the key frame for that bone's rotation from frame zero and paste it to frame 48. either way works. does this make any sense?
Are you working with consolidated channels?
Go to edit>preferences and be sure "consolidate channels" be unchecked.
It's easier to understand the way keyframing works when you see exactly what is going on with them.
bbuffington
Still couldn't get to work. Here is the file to revision I made based on your advice. Thanks for helping out. Also, similar problem with the middle character. I don't want 72 frames worth of her moving up in the air.
bbuffington
Selgin. I checked out my preferences and did not have that option checked.
jonbo
Post by jonbo »
when you change something in the workspace on a frame other than frame zero, a key frame is created at that spot and another one at frame zero for that change. the change will go from one key frame to the other. so you need a key frame where you want the action to start. by copying the key frame from zero to where you want the change to start, the change will hold until it hits that copied key frame.
bbuffington
I see it now! thanks.
