Do you have to move the patch layer?
macnavi
Post by macnavi »
When I have a patch layer above two layers, the patch layer stays on the same position on the screen when I animate the parts it patches. It doesn't follow the part it should hide. Is this correct behaviour and should I move that layer as well, or do I have to do something else?
Poptoogi
Patches
Post by Poptoogi »
Yes, you have to move the patch with the animation. If you are using bones it's easy enough to bind the patch layer to the appropriate bone which make using the patch much easier.
Practice random acts of kindness and senseless acts of beauty! Pause, consider, do! I dare you!
GCharb
Post by GCharb »
As guyver93 pointed, you just need to bind the patch layer to a bone.
Just look at a character from the wizard to see how it is build!
macnavi
Post by macnavi »
Thanks for the fast reply! I'm going to check it out now.
macnavi
Post by macnavi »
Interesting how that worked. Nice!
