Also is it possible to add -not sure exactly what it is called- but transparency that uses a mask -so you have gradiations of transparency -for example areas that are gray are only partially transparent? Unless I missed something this doesn't seem possible with imported png.
It would be nice to have this for brushes as well; I'm thinking along what Toontoonz was saying about the brushes limitations; if you could draw a brush that had variable areas of transparency maybe where the brush overlapped along the line.
I did a quick mockup in PSP to demo what I mean. The top line is a normal brush. Then I made one with a mask to make the brush fade out from the center. Now the lines look slightly different depending on the distance of the brush spacing and the resultant overlap -or lack of overlap.
