Hello everyone, i have this doubt, i didn't find how to do a color transform animation.
This means: in 1st frame a circle filled with green color, in the frame 20 the same circle, now is red, and the frames between 1 and 20 a color transition from green to red.
Does anyone knows how to do this in Anime Studio?
Color transform?
- Víctor Paredes
select the green shape, go to frame 20, and change the color to red in the style window.
- funksmaname
Using Pro, make a shape, Add an action called Red, change red on color picker to 255, remove blue and green by changing their numbers to 0. Make the shape in action. Make new action called Blue. Do the same as red. Then make green action.
You now should have three blend morph to change the color of the shape to anything you want.
Also you could add two more morph, visible and invisible by changing the Alpha setting on the color picker.
Dale
Dale
