Can pro 7 export image by image with transparent background?
Asterix
Post by Asterix »
yes. export animation / png / do not premultiply alpha
patricia3d
Post by patricia3d »
I am using Background PNG and Vector and Transparent PNG on top
in ASP8Pro and is working fine
see here
http://www.youtube.com/watch?v=mro5jkH7 ... r_embedded
Rhoel
Post by Rhoel »
Transparent png works on import too so this format works well both ways. So you can export a png with transparency, then re-import it again as a new layer.
sbtamu
Post by sbtamu »
Rhoel wrote:Transparent png works on import too so this format works well both ways. So you can export a png with transparency, then re-import it again as a new layer.
I do this when I use text that lags my PC. I always try to avoid AS text but sometimes it is a must.
Sorry for bad animation
Rhoel
Post by Rhoel »
I also build transparent graduated filters in PhotoShop, export at 300dpi, then import to to ASP and make immune to Camera Moves.
Works very well, especially on 'faux vignetting' - mimicking a real lens effect where the light levels fall off towards the corners.
Rhoel wrote:I also build transparent graduated filters ... mimicking a real lens effect where the light levels fall off towards the corners.
neat idea! do you use masking? or layer blending mode (multiply??)?
Multiply is the way to go (screen as the opposite). Have used this quite often. Again, think of rendering gradient PNG + BG once, then import as 1 PNG image, instead of letting AS calculate the effect for every time - saves rendering time!
Thanks! Good advice.
kphgraphics
Post by kphgraphics »
Think i am going to have to try this, saving render time is always good. : )
