Black lines change to yellow when rendering film
analbumcover
Post by analbumcover »
I have a problem that keeps popping up
All of my stroke lines are in black with no effects attached to them but when I try to preveiw or export them about 50% of them decide that they would rather be bright yellow. Thanks in advance for any help =)
jonbo
Post by jonbo »
You either have a color change key-frame somewhere in the timeline or maybe somehow the layer blending mode has been changed from normal. Check those first. If you still have the issue, upload a sample file with problem so we can check it out.
analbumcover
http://www.mediafire.com/?lky9do8faueyan4
here is the file in question. I looked at my sequencer and nothing seems to be in the keyframes that would explain my problem.
jonbo
Post by jonbo »
some of your strokes have the halo effect applied to them. use the select shape tool on those strokes, and set them back to plain. here's the fixed file.
http://dl.dropbox.com/u/53649091/Backdrop%201.anme
analbumcover
Thank you soo much for your help.
I dont know how I did that but you sir are a lifesaver
analbumcover
The problem is not going away. =P
I have debut and I cannot load the fixed file.
I re drew the background on a new document and made 100% sure that the effect was set to plain and the same thing happened again.
If I use the select object tool and higlight the affected area set it to halo and then back to plain the problem still persists. I don't get it.
jonbo
Post by jonbo »
Are you using styles? You had overlapping shapes so its hard to get to the affected one. The effect is on the stroke of the shape not the fill. Here's the file fixed and saved from DEBUT should work.
http://www.mediafire.com/?lcbumtm0bcxhzx3
analbumcover
Nothing I did seemed to work but I did have success when I did a redraw for a third time.
Thanks for giving me all that help, I am sure whatever the problem was that debut was making it unfixable. I might just get pro for my next project.
You went above and beyond for me on that one. thanks
-an album coverX
