Theatre light on curtain effect?
jorgy
Post by jorgy »
It seems like all the big shows are doing it: projecting a logo onto the curtain before the performance begins. I'd like to duplicate this effect in moho, especially where the logo "stays put" as the curtains open.
I searched around online for examples of this, and this was the best I could do:
http://pascalroche.free.fr/page_lumiere.htm
If you scroll to the bottom, there is a series of pictures where images are projected onto various objects - a car, sides of a building, walls, a lawn, etc. I'd like to be able to do this projected onto a theatre curtain with moho.
Any ideas?
Thanks!
bupaje
Post by bupaje »
Have you tried using the layer blend modes to do this? If I understand what you are saying correctly then you should be able to just put your logo on a layer and set the blend mode to something like overlay. Please explain further if I misunderstood.
rylleman
Post by rylleman »
I think you should be able to use the same technique as I have done in thisFishlamp for your curtain, only I got the "logo" moving and the "curtain" stay still.
It's based on LMs Object Warping tutorial.
If you think it would be to any use for you I could send you the work file..
jorgy
Post by jorgy »
bupaje wrote:Have you tried using the layer blend modes to do this? If I understand what you are saying correctly then you should be able to just put your logo on a layer and set the blend mode to something like overlay. Please explain further if I misunderstood.
I think that would work if the curtain were completely flat. However, the curtain has pleats (is that the right word?) like this:
See how the spotlight is irregular on the curtain? That's the effect I'm looking for, except that instead of a round spotlight, I want to put up an arbitrary figure.
Thanks,
jorgy
jorgy
Post by jorgy »
rylleman wrote:I think you should be able to use the same technique as I have done in thisFishlamp for your curtain, only I got the "logo" moving and the "curtain" stay still.
Thanks! That looks like it will work! I'll give it a try.
jorgy
(and I even replied to that tutorial, wondering how I could use that technique... LOL)
jorgy
Post by jorgy »
Thanks Rylie, that is going to work great for me! Don't worry, when I get the project done I'll post it here.... :-)
