Patch Layers Not Working When Rendering
Bobsten
Post by Bobsten »
Ive put the patch layers on, and binded them to the right layers but when i render the project it shows the lines that shouldn't be there. (The front arm and both legs)
Please help me with this. :P
Image[/img]
jonbo
Post by jonbo »
Is it only in the render that they don't show up i.e. are they working in the workspace? What format are you exporting? Can you post the anime file so we can check it?
Patches will not work if yor render to SWF. See Appendix.
Bobsten
Post by Bobsten »
The patch works perfectly when in the work space and im trying to export in AVI but it still wont work
jonbo
Post by jonbo »
You could try Quicktime, H264 or PNG compression. If you don't have quicktime installed on your computer, you should install it. ASP needs it to play MP3 audio files, so it would be good to have and it has better codecs for video.
Bobsten
Post by Bobsten »
This is a picture of it while working on it and ive tried all types of exportation but nothing worked
jonbo
Post by jonbo »
Upload the anime file to a file sharing site like DROPBOX or MEDIAFIRE , both have free accounts. That way we can check it on our end.
Bobsten
Post by Bobsten »
Heres a video of it that has been converted from avi to wmv
http://www.mediafire.com/?wqgqaktm6uayc7d
jonbo
Post by jonbo »
The video shows the problem but doesn't let us see what's causing it. You need to upload the anime file for us to be able to help you.
Bobsten
Post by Bobsten »
hahaha sorry about that
http://www.mediafire.com/?ro25c5319lrhiqd
that should do it :oops:
jonbo
Post by jonbo »
Its the layer shadow and shading effects that are causing the problem. If you turn it off on the layers you have it applied to, the patches render fine. I don't use layer shadows much so I don't know why it messes with patches. It must push the shape in the z axis so that its in front of the patch. If you want to keep the effect, instead of patches, you could use actual shapes with no stroke to cover the joints.
Bobsten
Post by Bobsten »
Thanks jonbo that fixed everything haha
Thanks!!! :D :) :o :lol: :wink: :P
