I have a circle. In frame 0 i used "hide edge" on two points (and the stroke is invisible) but in frame 20 i want that the stroke on these point is visible.
How do i?
One way would be to make the circle w/o any fill or stroke then make each arc its on shape then fill it with stroke turned off then use the opacity for the arc that you want animated.
