Thick lines and layers
buddhanature28
Post by buddhanature28 »
Hi
I am new to anime studio pro and I have been working on this cartoon girl. I didn't realize I could adjust the line width until after I had gotten this far. Is there anyway I can go back now and change the lines to be thinner. So far I haven't figured it out. Also I constructed her out of different layers, (an arm on one, half the body on another and so on). Is there a way to merge the layers together, I also can't figure that out. Thanks!
Heather
Re: Thick lines and layers
Line width: if you used styles, just edit the stale. (I bet you didn't.)
Else just select each shape with all points and use the line width tool.
Merge layers: this is not necessary, just put all stuff which belongs together into a bone or group layer. If you still want to, copy all stuff from one layer and paste into another. As long as you didn't perform any layer translation or scaling, it will line up perfectly.
buddhanature28
Thanks for your reply. It was very helpful. Heather
trung277
Post by trung277 »
It is valuable to share, thank your understanding.
