How to avoid bone vibration?
lda.com
Post by lda.com »
Vector bone animation is rendering fine but png images imported from photoshop using the AS script are vibrating like a tuning fork when still ( not animating or moving).
Any tips on how to stop them from vibrating?
I searched but couldn't find anything in the forums.
Help if possible.
lda.com
Re: How to avoid bone vibration?
Post by lda.com »
Bump
Guys any help here? I am stuck with my work.
rylleman
Post by rylleman »
Do you use bone lock?
Yes, bone locking is a possible culprit. Anotehr one s not exactly matching keys: you think they are identical when in fact they're not. Try copying to make sure bones really stand still between movements.
lda.com
Post by lda.com »
Nope.
Do I need to lock it for the whole time frame or only when not moving the bones?
lda.com
Post by lda.com »
slowtiger wrote:Yes, bone locking is a possible culprit. Anotehr one s not exactly matching keys: you think they are identical when in fact they're not. Try copying to make sure bones really stand still between movements.
I try copy the keyframes or press reset all the bones.
Haven't learned locking yet, will give it a try.
are you sure the keyframes aren't set to noisy?
If so, change them to smooth.
rylleman
Post by rylleman »
Do they always vibrate or in some circumstances?
I've encountered this on some rare occasions and then it was usually due to some complex character setup with many folders nested in each others with motion in different directions.
Can you share your anme-file and image sources?
lda.com
Post by lda.com »
rylleman wrote:Do they always vibrate or in some circumstances?
yes it is kind of exactly what is happening, one photoshop file with different layers plus eyes and mouths separate added from anime studio are all in one group and I am moving the whole group in and out of the scene.
lda.com
Post by lda.com »
This is exactly what I am facing, have you sorted out this problem in your files?
rylleman
Post by rylleman »
On these occasions I've done a little rerigging and redistribution of layers. No universal cure, sorry.
lda.com
Post by lda.com »
Thanks for your help.
I realize this is not happening with vector images created by character wizard. Also I did not used smooth key frames, they were linear and did not used lock bones as well.
So lets see me try with vector graphics and then see how it goes.
