Stroke around a add point line
Asterix
Post by Asterix »
With freehand tool I can check auto-stroke (to crease a stroke around the shape). Is it possible to do so around a line create with add point tool?
Thanks
ASP 7.1
Re: Stroke around a add point line
Use "create shape" (U).
Asterix
Post by Asterix »
slowtiger wrote:Use "create shape" (U).
Thanks, but can I make it look like the freehand tool.
The one at bottom is add point tool converted into a object.
The top one is freehand.
ASP 7.1
AS can't guess which thickness you want to apply to points if you create them with "add point". You can easily change line thickness at each point later.
