I created some files using acrylic then import into moho.
If I exported as illustrator 7, the layer frooze .
If I exported as illustrator 5, moho load the layer well and I can move the point, but can't fill the layer , but I can 't see holes in .
The outline color can change, the inside cannot?
Why?
This is the latest file: a simple arm layer without colors.
http://s42.yousendit.com/d.aspx?id=0K55 ... SUS20VIGMG
Illustrator problem
- red hamster
- red hamster
Ok the problem was a segment of the upper left part of the arm was not connected properly when it was exported.
The solution is to give the arm a fill inside of you illustration app and then bring it into moho.
At least that is what I did. I brough it into freehand gave it a fill and then converted it to illustrator inside of flash. This is another good tip if you have Flash. Flash exports perfect .ai files for moho in the ai 8 fomat.
I have attached a moho file with the fixed up converted arm.
http://www.bigbackcomics.com/mohotests/armfixed.zip
Cheers,
Cheers,
Jeremy Rayment
president, CIDA (Chief Interactive Design Agent)
Big Back Comics
jeremy@bigbackcomics.com
Big Back Comics
- red hamster
Thanks. I found that every file that I made with that program has this difects but I can correct it.
The draw features seems to be easy to use than the moho 'one.
I can't afford freehand and don't want use warez software ,so acrylic is a good tool.
That "arm" was just a try of the export functions , not important but I appreciate .
Regards
Regards
