Hello... I am a bit confused in my work as I suddenly can't see my keyframes anymore in my timeline.
Everything works as it should, but no keyframes are visible. What happened. I probably switched accidently some setting.
Without seeing my keyframes, work is impossible, I work with Anime Pro 8
Thanks for your time
Dust
Time Line
- neeters_guy
Re: Time Line
Check the scrollbar to the right. Maybe you scrolled down too far.
Admiral Halsey
Re: Time Line
Probably you just accidentally switched on another layer which doesn't have keyframes. That sometimes happens to me as well. Keyframes are only visible for those layers that have animation.
Re: Time Line
Thanks.
It has indeed solved itself. Was annoying, but somehow everything functions properly again.
So I am back to work
Re: Time Line
It happens to me often but i just restart de aplication and i can see the keyframes again.
My cartoons: www.youtube.com/totallyanimated
