Hello everybody, How can I fix my animations?
My problem is this:
As you can see, the Van looks terrible, the movement is not fluently and softly, I'm using AS8, demo and I have tried using
* Avi without compression/ Full Keyframe/ Microsoft Video 1/ Mpeg4
* Animation/ million colors
And i get same results. PLease help me.
Fix Speed Video - Reparar la velocidad del Video
dragon4zul
Re: Fix Speed Video - Reparar la velocidad del Video
I don't think you have a problem with the number of colors or compression of the movie file. How does it look when you play it back in the main window of the program? You can fix the speed by selecting the key frames and moving them forward or backward on the time line. The van flies over the hill, which is a bit funny, but then for the rest of the sequence I think it moves well. You can stop directly on any key frame and change it if you don't like the movement.
Steve
http://www.youtube.com/user/toonlyrics
Music Website: http://www.singadream.com
Steve
dragon4zul
maybe you don't see the problem because you don't work with video but the movement of the van is very hard i need to be softly for the human eye, I would be dismissed from my job If I use this video he he he he
Have you tried to change the movements you don't like?
I'm a beginner, but there are experts in this forum who will help you if you can clearly explain your problem.
Steve
Steve
dragon4zul
Thanks the movement is only one as you can see in the video, the probem is the bit-ratio
that's all I need to fix. Thanks for your Comments
