imported movie audio
ulrik
Post by ulrik »
I tried to import a movie file into a moho project and it's working fine except for the audio part, it's not sounding at all, is it supposed to work?
The movie file is a .mov, I'm using mac and running osx 10.4.2.
Rai López
Post by Rai López »
...I think that you must import it too again, but like a Soundtrack... import your movie file and then go to File --> Import --> Soundtrack (or Animation --> Select Soundtrack...) and load your movie file again, you'll get it! (I think...) CIAO!
ulrik
Post by ulrik »
Yes that worked :D
Thanks Ramon!
Rai López
Post by Rai López »
...IT WAS A PLEASURE! :D
mr. blaaa
Post by mr. blaaa »
Ramón López wrote:...IT WAS A PLEASURE! :D
wow, for me too^^
Rai López
Post by Rai López »
Mmmm... Maybe only a "lapsus", cause I remember have done this without any problem in the past, but now, when I go to "Select Soundtrack..." or "Impor --> Soundtrack..." and try to load a *.mov file for import his sound, I can't because in the "Select Sound File" Window only are mostrated "Audio Files" and I can't change it because is the only one option, am I made me mad? I dreamed this was possible?? In that case, who is more mad? the madman (jaja...) or the man which follows the madman? :roll: (...)
mr. blaaa
Post by mr. blaaa »
Ramón López wrote:I dreamed this was possible?? In that case, who is more mad? the madman (jaja...) or the man which follows the madman? :roll: (...)
Hehehe, cool that you share this with us. First i must laugh and then i must tell you that you can still import .mov as audio.
You are not mad.
Wait, do you grow and eat peyote???
Just enter "*.mov" in the "open" line and .mov's will be showed again. No panic :wink:
Rai López
Post by Rai López »
Thank you SUPER. blaaa!!! :D I knew that this should be possible cause I did it in the past without any problem/complication cause I rememered that I could change Tipe: "Audio File" to "All Files" in Select Sound File window... Anyway it was only a "lapsus" (as I was afraid) and I'm happy now/again :) *CIAO!*
mr. blaaa
Post by mr. blaaa »
duty :wink:
