Hello,
Is there a way to add points to a curve without deforming the original curve. Example, you have a circle (not filled) and you want to open up a small gap on the circle (hide or delete edge would do). When I add the points where I want to remove the small portion of edge (to hide edge or delete edge) the circle deforms. Wondering if there is an exact way, not a work around (re-curving the original line, etc)
Thank you for any help.
Dale
Adding Points to curve
Re: Adding Points to curve
Select shape, menu "scripts > split curve".
Many thanks.
