Layer blurry without any reason
Diana Kennedy
Post by Diana Kennedy »
Hi!
I sometimes face an odd phenomenon and today, again. I have a vector layer that is "blurry" without any reason.
See Screenshot below:
Of course, I carfefully looked if there's any setting wrong like "soft edge" or on the layer,"blur radiu"s and so one. Every setting is set to "none" or "plain". Settings of the eye-underline right is EXACTKY the same as of eye underline left, but, as you can see, underline right is blurry. Do you know this issue and if yes, how to fix it?
Re: Layer blurry without any reason
Try to isolate the blurred and not blurred shapes and share them with us.
Diana Kennedy
Hi Genete,
I did make a copy of the file and deleted out all layers with the exception of the two said layers, one being blurry, the other not. I made an interesting discover: Taking them out of their folders made the phenomenon disappear. Both are not blurry then. But the settings of the folders seems to be ok too, so I don't understand. Anyway, I kept the layers in their folders.
Here is the file: It is an ASP9 file, so I hope you have ASP9
Public Dropbox file location:
https://dl.dropbox.com/u/61460662/blurlayer.anme
Wiseling
Post by Wiseling »
Hi Diana,
please check out Edit --> Project Settings. I think the phenomenon occurs because Depth of Field is enabled in your file. Without Depth of field the blur is gone...
Regards
Iris
Diana Kennedy
Depth of field disabled, and yes, it's fixed now. Thank you a lot, Wiseling.
