Smart bones - Need help setting the start position of a bone
DRStudio
Post by DRStudio »
Hello everyone.
I've recently upgraded to AS Pro 9 and i'm having a hard time setting the start position of a smart bone so it stays turned fully left when i'm on frame 0 (as it shows at about 8:15 in this video).
No matter what i do, the bone will always be straight (90º) after i create an action and get back to the bone layer. In other words, my blink action will only happen when i rotate the bone 90º (not 180º). I've not binded the layers to the bones, as i know that won't work with the smart bone.
Can anyone help? Thanks!
Maxwell
Re: Smart bones - Need help setting the start position
Post by Maxwell »
try adding bone constants to the bones i had the same problem when i started using ASP9 and i am only a beginner in AS once you added the bone constants you just do all the rest the same way
hope this helped
DRStudio
Post by DRStudio »
Thanks, Maxwell.
I've tried setting the bone constraints, but still no luck. No matter what i do, the bone jumps straight to 90º the moment i create one action, and i can't set it fully left on the frame 0 of that action. :?
Setting a keyframe on frame 1 of the action didn't solve the problem either.
Seems so easy on the video... Couldn't find any help on the manual. Do you or anyone here have other suggestions?
Thanks again!
Maxwell
Post by Maxwell »
DRStudio wrote:Thanks, Maxwell.
Thanks again!
let my try a basic step by step tutorial...
1. create a small bone
2. set the bone strength to 0
3. rotate and set the bone in the position you want it to be
4. set the bone constrains, on 1 side put 0 and on the other side put whatever you want and need
5. deselect the bone you were working on
6. repeat until you get as much bones as you want and need
i am not a professional nor a good advice giver but this should not be too difficult. sure you have some problems in the beginning but once you get the hang of it you will never forget
and this webinar might help a lot
take your time and watch it it is very useful
http://www.youtube.com/watch?v=pVfvkYBb1SM
or you could check out my source file that i just posted it is a fully functional character and if you need anything from there you can get it here
viewtopic.php?f=8&t=23640
hope this helps
Yosemite Sam
Re: Smart bones - Need help setting the start position of a
Post by Yosemite Sam »
heshajohn wrote:Your bones are natural healers. At the location of the fracture, your bones will produce lots of new cells and tiny blood vessels that rebuild the bone. These cells cover both ends of the broken part of the bone and close up the break until it's as good as new.
lol, huh?
Jimmy Mills
Some of my Moho Pro work.
My Demo Reel: https://youtu.be/_kSCno4Wd3c?si=gNT7d27R7sM4jjqq
Buddies Ep 4: https://youtu.be/f8Zbzo2mpHA?si=4EyxhBOrgOxkDoSO
DRStudio
Post by DRStudio »
Maxwell wrote: let my try a basic step by step tutorial...
hope this helps
Thanks again for the help, Maxwell!
Finally got it after watching the webinar video. Thanks also for posting your character (that helped also).
When you set an action, the default position of a bone is 90º when on frame 0 (as soon as you get back to the mainline action). So in order to make a smart bone work 180º, you have to set a keyframe on frame 1 (say, fully left, in my case) and from there add one keyframe (or any number of keyframes as needed) for the opposite direction (fully right).
I'm now able to make my eyes blink! Still a long road ahead, but it's been a funny journey lol!
