wacom pen
robint
wacom pen
Post by robint »
Hi
does anyone else have a problem using the pen and the add point tool
I find its a bit counter intuitive having to click and drag (as with a mouse - no problem), but with the pen its dab - drag - lift - dab, and its the lifting of then pen thats causes inaccuracies especially tracing of ink drgs where you cant see the spot too clearly
If I could just trace by dabbing points and then join after that would help, but i dont think there is a joint points facility
I found that making one of the tablet button a click helped (more like a mouse) but then I might just as well stay with the mouse (unless i want to use it for freehand)
Any tips on this?
btw i found the pen much more natural with the abominable PS pen tool cos thats just dab drag and more to next cp dab drag
not doing it right?
Robin :D
AmigaMan
Re: wacom pen
Post by AmigaMan »
No I don't find it a problem at all. I only ever use my Wacom pen/tablet (never use a mouse) and I find it easy enough. Maybe you just need to get used to using the Wacom?
Lukas
Re: wacom pen
Post by Lukas »
I have no problem with it either.
nobody1954
Re: wacom pen
Post by nobody1954 »
It does take some getting used to. After you get the hang of it, you probably will find it much easier to use than a mouse. I us a VisTablet Penpad attached to my PC. Much better for drawing than a mouse, once you get used to it. Good luck.
robint
Re: wacom pen
Post by robint »
yep its my finger trouble, i gotta unlearn PS pen tool motions
but i also removed the transparent cover from my tablet so the pen is directly touching the surface rathern than through 3mm of perspex, thats made it much better
Cheers :D
