What range will "Source Depth" in a Particle System cover?
drumlug13
Post by drumlug13 »
I'm working with a particle system in anaglyph 3D. Having a little trouble figuring out what range the "Source Depth" of the particle system is covering.
Example:
If the Particles Folder itself is set at a Z depth of 0, AND the "Source Depth" in the "Particle Options" is set to 3 ...
Will the particle be generated at Z Depths of 0 through +3 ?
-Or-
Is 0 the middle and particles generate at Z Depths of -1 through +1 ?
Adam
