I'm using AS 9.5 and I have run into an issue twice now that I have never run into before with previous version.
When I hit play in the program, everything is exactly as it should be. However, when I render, the switch layers don't function in the rendered version. When I hit play in program, for example, the mouth works like I want it to. The rendered version, however, the mouth doesn't do anything at all!
Is this a glitch or did I use a new feature that I didn't realize I was using that is causing this to happen?
Preview Works but Rendering Doesn't
Re: Preview Works but Rendering Doesn't
are you using smart bones with the switch layers? I've noticed something similar with this recently.
In this file, yes.
In my previous file that had the same problem, no. In that file, I was using actions.
Just got it figured out.
"you have to uncheck the empeded option in the MB bone layer to fix it" - Parker
Thanks Parker!
Thanks Parker!
Basically, there was an embedded script in the bone layer that caused the issue.Kedric wrote:Just got it figured out.
Thanks Parker!
Kedric wrote:Basically, there was an embedded script in the bone layer that caused the issue.Kedric wrote:Just got it figured out.
Thanks Parker!
Kedric wrote:I'm using AS 9.5 and I have run into an issue twice now that I have never run into before with previous version.
I am having this problem. I have a character walking with the action panel and it does nothing when I render it, I have no idea where the empeded option is or what the MB bone layer is.
