I made a scene of an underground worm lair. I used a stroke bush to give the dirt a rough look. When I rendered the video, the stroke vibrates. It doesn't do this in the preview. Is there away to stop this behavior?
Here is a video
prevent stroke brush from moving in animation
Re: prevent stroke brush from moving in animation
The two times I've ever used a brush I got the same result. If there's a solution, I hope someone posts it.
~Danimal
Have you tried checking the "Minimize frame-to-frame randomness" option in the brush settings?
Who says Moho is worse than Adobe Flash?!
That seems like a great solution, and that feature didn't exist in the version I had previously used so I did a test file -- still the same squiggly motion.Tradley wrote:Have you tried checking the "Minimize frame-to-frame randomness" option in the brush settings?
~Danimal
it somewhat worked, there is still an unaccountable amount of movement though.
Uhm, that tunnel is just part of the background, right? So just render it (with all other BG elements) as one image and import that.
slowtiger wrote:Uhm, that tunnel is just part of the background, right? So just render it (with all other BG elements) as one image and import that.
Wow, the simplest solution is usually the best one. Thank you.
