Best character import practices
Pesto
Post by Pesto »
I was wondering what users think about the best way to import a character made in another program, and which programs are best. I currently use iDraw for vector work (don't have Illustrator). What is best way to save a character in layers? What is best file format? Any other tips would be appreciated or are there videos I could watch on this stuff?
Thanks
Re: Best character import practices
Best recommended practice is still to create characters in AS directly. This way they're optimized for animation.
AmigaMan
Post by AmigaMan »
I agree with Slowtiger. Create your character's in Anime Studio. There's no point in using other Vector software for drawing your character's when you can do it all in Anime Studio and save you causing yourself extra problems. Design your character's on paper or in drawing software then import the image into AS and trace it. That is by far the easiest and best way.
Telemacus
Post by Telemacus »
AmigaMan wrote:Design your character's on paper or in drawing software then import the image into AS and trace it. That is by far the easiest and best way.
Whilst I tend to agree, tracing can be a little problematic though: you'll often end up with several hundred points (btw, I've always thought AS should have a point counter).
Even after using the "simplify curve" script, there are still hundreds of points for shapes that, really, should only require a dozen or two.
AmigaMan
Post by AmigaMan »
You end up with very few points. I've never used the Freehand Tool in Anime Studio. Always use the Add Point Tool (I should have mentioned that) to trace an image. It's very easy once you get the hang of it.
Telemacus
Post by Telemacus »
Oops, I see what you mean, I thought you meant the "auto-trace" feature!
AmigaMan
Post by AmigaMan »
Oh no no, I never even thought about that as I've not used it. I should have made myself clearer from the start. You can see why I usually leave the question answering to the likes of Heyvern and Slowtiger! :D
Pesto
Post by Pesto »
Thanks all for the replies. I'll check out more tutorials to wrap my head around the drawing tools.
sceech
Post by sceech »
It's also fairly easy to reduce the number of points on any drawing done with the Freehand Tool. Just highlight and hit Delete, and in most cases the shape doesn't change much, if you are just getting rid of excess points. Just Lasso and Delete! Gets you down to the minimum number fast.
sbtamu
Post by sbtamu »
Some times I'll just make a circle around the image to be traced then I'll split the curve 4-8-10x or even more. I am at the point I can pretty much guess at how many points it takes to trace an image. Then I do a rough around and start dragging point closer to the image; do this until you get it looking like the image then I zoom in real close and start adding point to get in all the nooks and crannies.
Sorry for bad animation
Having used both Adobe Illustrator and Anime Studio for many years and proficient with both apps, the time required in each to produce the same character is the same for both apps in my humble opinion. Of course if I do it in Illustrator I double my time REDOING it in Anime Studio.
Once you know what you are doing in both programs getting to the end result is a matter of drawing skills and manipulating points.
The process in both apps is different, and in some cases VERY different, but at the end of the day it's how the resulting creation is to be used. If you are invested in Anime Studio for animation (great choice by the way) then it makes so much more sense to use that tool for creating the characters originally since it will save time, and allow "testing" your creations to see how they animate in the program you are creating them in. In both cases it's probably going to start with some sort of "free hand sketch" scanned in or drawn with a stylus and traced in either application.
Bezier vector apps will produce fantastic final results, but without a way to "test" how it will animate the resulting creation will most likely have to be drastically altered to work in Anime Studio. Even if we had "perfect" import of bezier based vector files with points exactly where they were originally placed, those points will have to be moved and additional points added or removed, in order for the character to animate correctly. Often drawing a "still" image allows cheating the placement of points and their curvatures that would prevent good animation. When creating in a "still" based drawing app, you can't see how well your shape and point placement will work when animated. At least not until you get it into Anime Studio and try it out.
Often I draw or trace, say... an arm for the character. The arm has to bend at the elbow. If I simply drew the arm on paper, or in another drawing app, I am trying to make it "look good" and not thinking about where to place points so it can bend. I would also draw what the arm should look like when bent at the elbow, but still it's purely a visual reference.
Once in Anime Studio, I trace that arm and place points where I think it will work best to bend the arm smoothly and look good. I then add bones to test out the motion. I can tweak and adjust the point position, add some smart bones to smooth it out.
I could never have predicted where those points should go when drawing on paper or in Adobe Illustrator or even in Anime Studio, until I get to that point when I'm testing out the motion. There is just no way that you will ever draw something in another medium and import straight into Anime Studio and magically have a character ready for animation. There is always going to be tweaking and adjusting.
Some people can draw in Adobe Illustrator as quickly as drawing on paper. In that case it doesn't matter what program you use to sketch out the original character designs. Using other vector apps to do this is fine if you feel comfortable with it and it helps to get your ideas and designs created quickly. You can simply use those as tracing templates in Anime Studio.
The main thing to keep in mind is that in Anime Studio, point placement and shape creation is critical to animating a character well using bones. Points need to be placed in such a way as to allow those shapes to bend and move properly. Layer order, shape order, masking etc. All of these things need to be addressed in Anime Studio to determine the best way to set it up for animation. Your original character designs, whether drawn on paper and scanned, or drawn in Adobe Illustrator, should always be considered tracing templates to be redone in Anime Studio.
Just my 2 cents. :)
nyaky
Post by nyaky »
Hi ,
Personnaly , i've Illustrator CC and the import in format SVG work perfectly and the character that i draw in Illustrator is always editable ..
Maybe the answers at your question is the format SVG.. ( But i don't know if Idraw can export in SVG )
Sorry for my english , i'm french :lol:
See you soon .
