Photoshop CS2/Animation workflow?
Whatever...
ingie01
Post by ingie01 »
Has anyone discovered a workflow using Photoshop CS2 and Moho? I really haven't spent a lot of time experimenting with this, hence the question. I have just started using Moho and find it facinating it seems to have a great deal of depth and a wonderful workspace setup.
You'll know when you get there! My Dad
rylleman
Post by rylleman »
Not quite sure what you're after but I'm using phshpCS2 and Moho together all the time.
All my artwork is either created in Photoshop or processed in it and from there I export it as .png´s for import and animation in Moho.
mr. blaaa
Post by mr. blaaa »
1. never export interlaced.
ingie01
Post by ingie01 »
I use PS to process my art work to png also. I was wondering about the animation feature in CS2. Is it worth the time to explore and is it compatable with Moho?
rylleman
Post by rylleman »
I have been trying photoshops animation feature but it's very limited. What you can do is change visibility and such over time and make drawings over time, which I'll use it for if I can get it to work satisfactory with semi transparent brushes.
I don't think animating something in CS2 for Moho import would work that well since you have to export it at a series of still images, besides Moho is so much better at animation. I think you should continue working as you have done it, process images i photoshop and export them as png´s, then import and animate those in Moho.
Rhoel
Post by Rhoel »
I use Photoshop and a digitising tablet to make ny backgrounds. Moholooks after the animation. This gives a very "high quality" feel to the final animation. Vectored backgrounds always makes the animation look "cheap".
And before this becomes a flame war, try outputting a still with the same animation, but one image with a vector BG and one with a photoshoped BG. Its one of the key reasons Jananese animation looks good - the animation is often very limited but the backgrounds are exquisite. Have a look at Ghost in the Shell.
The secret for good photoshop backgrounds is to make a layout on paper first then scan that into Photoshpt and paint over it. Use the wet brush in high transparency and the results are very good.
ingie01
Post by ingie01 »
Thank you all for your comments and suggestions. Such a pleasure to have educated responses.
kind reguards
ingie01
