problem frame by frame animation in as 10 download
sun
Post by sun »
hello. in differnce to as Version 9 i ve a Problem with Frame by Frame Animation with Switch layers in as 10 (download Version). exactly with the onion Skins. the onion Skin of the first vector layer can one see, the onion Skins of the second and the next verctor layers dont appear whatever i do. When i create the second vector layer there also dont appear the red bar in the timeline and the layer Symbol with the eye. Has anyone else this Problem? Is it a matter of the download, of the new Version or do i do something wrong?
p.s.: i work with Windows 8
Re: problem frame by frame animation in as 10 download
The vector layer has to be active in the switch for it to show in onionskin. Automatically making a newly created layer invisible until that frame is disabled in switch layers for v10 (because switches do this anyway). That way you can adjust the switch keyframe timing without having to worry about layer visibility.
If you really need the layer invisible until that frame, create it outside of a switch layer.
sun
Post by sun »
Hello Synthsin 75. I m not really sure if you intended what i did next (i m not a native Speaker and i didn t understand the whole advice :roll: ) But because of your words i found out what to do: i double clicked the main-Switch-layer, in the layer Settings Dialog i chose the switch tab and CHECKED "interpolate Sub layers". with this checked i was able to work with onion Skins in the Switch layer like it is shown in the as tutorial on page 200 (Help-tutorials). Maybe later i have to uncheck it... So thank you :idea:
p.s.: in Version it all worked without "interolate Sub layers" checked. i dont know why :D
sun
Post by sun »
Version 9.2 i ment
